[SOLD] The $900 Silverado 2500
Galandorian
Albany, New York
Picked up this beautiful girl last night for $900 cash money.
285k on the odometer, owner claims 55k on a rebuilt Jasper 6.0L, but has no paperwork.
Battery was dead, needed to be jumped.
Couldn't switch gears without slamming the gas pedal, and couldn't let it drop below 2K RPMS on the way home or the truck would shut off completely.:p
Was definitely an interesting drive!
As of purchasing it, I've found these issues:
1) Needs new battery
2) Bogs down / shuts off under 2k RPMS
3) Transmission line leaking A LOT
4) 2nd row door won't open at all
5) some line is cut off under the truck, haven't investigated to see what it belongs to
6) needs oil change
7) needs new breaks + maybe rotors
8) bald tires
9) no actual light bulbs in the head light housings
10) no passenger side mirror
11) glove box latch doesn't work
12) hood won't fully close
has a lot of rust that I may or may not try to fix
my goal is to make it drivable, then turn it into a 155+ dB audio vehicle.
Galandorian
Galandorian
Albany, New York
we threw a temp junk battery in (no pics) just to move forward
then we looked at the transmission line leak
After some carburetor cleaner and wiping with a rag, the vehicle seems to be idling much better
it was about 10pm at night and I didn't trust driving it on the road in case it broke down, but we'll probably seafoam treatment it tomorrow, and hopefully then it'll be able to drive normally
Chubbs
Assume the tranny wouldn't shift gears because there wasn't any TF in it. i would suspect some level of internal damage that may ultimately result in catastrophic failure.
Since it needs TF to maintain operating temp, the tranny was certainly running hot & possibly cooked it medium-well depending on all of the factors. I would have a backup plan for the trans.
Check engine light? Regardless, plug in the OBD scanner and see if it pulls any trouble codes. Get a handle on underlying problems.
What's up with the audio/bass-mobile thing?
6) needs oil change
8) bald tires
I bet he would've took $500. At least it's dbc.
Galandorian
Galandorian
Albany, New York
OBD scanner doesn't appear to work on it, guessing since it's a Jasper engine that was put in by the seller, and the ECM probably isn't setup correctly.
I hopefully won't own it long enough to see the tranny fail.
My goal is to build a semi-large system in it, take it to a few shows, and then sell the vehicle for around $5,000 when it's said and done.
nah, he wouldn't take less than $900.
his facebook post had 128 comments within an hour posting, with people wanting it with cash in hand
only reason I got it is because my sister dated one of his friends in HS, so I got to skip straight to the front of the line
An interesting build. Best of luck.
Thanks :D
Galandorian
Galandorian
Albany, New York
After a lot of kicking, prying, and other things, we got the back door open and found this bottom latch rusted and completely useless
Not as much smoke as expected, but the car at least didn't turn off for the entire duration lol.
Now I can atleast have access to the interior, and start ripping out the headliner, panels, seats, etc.
Looking for an 8' topper for under $150 as well so I can keep my batteries and amps in the back.
Then I'll have roughly 40 cubes gross inside the cab to fit my subwoofers.
Also gave her the old seafoam treatment.
Looks like you might have an exhaust leak under the hood.
rowerowe614
