[SOLVED] Help! No transmission indicator, No Manual gears after transmission swap.
petethepug
Michael
SoCal
@NickTransmissions , I hate to say it, but your reputation has kinda preceded you. The forum staff should get you an honorary no cost vendor placement.
You’ve helped so many I can’t keep track anymore. We almost need a template to paste on the thread that requires all the relevant info pre-filled prior to going forward.
Sorry for your mis-lead and about not giving info on my location I thought my questions would not involve sharing my location, plus I solved the issue by connecting the tcm harness to the control unit then reading the old TCM through Obd2 port using hp tunners then re-writing the Old TCM's file in to the New tcm and everything worked just fine till now, but when idling around 1000 - 1250 rpms on highways I get a little feeling of a slight vibration under my feet, and another concern I got I feel a little power lose is it possible to replace transmission and lose power, when I had the old transmission whenever I floored the gas pedal at around 45Mph I could get the traction control light flashing but now I feel less power.
Did you perform the Adapts function after this? Even so, it takes a few days for the engine and transmission computers to learn so the driving will improve over time.
NickTransmissions
Sin City
The transmission bench
Thanks, Michael! Completely agree about the relevant info; I have been trying to come up with a user-friendly template that allows folks to quickly/effectively communicate their questions and requests for help while giving us everything we need to respond with actionable direction/feedback.
Will keep the forum posted on anything I can come up with and would be happy to be a sounding board for anyone else with ideas.
JayySalas
