SOLVED: Rear climate controls no longer turn on
treehan77
TYF Fiend
Crestview, FL
My 05 Yukon has the rear climate controls (digital panel in the back of the center console for second row passengers to change temp/fan speed etc). Used to work. NOW it doesn’t even turn ON. Anyone know if this is common problem? I checked the fuse already, supposedly the INFO 15A under hood. What else to check?
Possibly related, the aftermarket radio had to have a new Bose adapter installed after it started whining. I rarely have back seat passengers, so I don’t know if it quit right after that, kinda doubt it.
SilverSport
is the front control set in the upper control console to allow rear controls to be used or is it set to OFF???...(perhaps different in my Denali)
Good luck with your Yukon
Bill
Trey Hardy
Eastern North Carolina
Mine burned up I had to put a new ac control on the back of the center console to get the rear ac back up and going
I wanna say it was around 50-100$ maybe? It’s been awhile
treehan77
treehan77
TYF Fiend
Crestview, FL
Popped it right out with a trim to Bonus -cleared the code and unplugged, plugged back in and it works again. I saw a TSB for this that came out years ago with a revised part that fixes it I guess. If it only happens once every 20 years I’ll deal with it
Aviator_78
