Sooooooo, I bought a PPV ...
The_Burban
Your headlights new? Probably next for me.. but considering the updated look ones also...
eBay has OEM types for $100.
RichardCranium
RichardCranium
Mebane, North Carolina
Yup, best investment for the outside look of my Tahoe that I've made. My factory lenses were badly yellowed. I can't recall the vendor I went with, but it is surely documented in my headlight link below in my sig.
RichardCranium
RichardCranium
Finally decided on a head unit, of course the purchase got escalated when the auxillary and radio kept toggling back and forth.
Picked up an Alpine head unit with a 7" touchscreen, and installed with with steering wheel controls with a complete installation kit from Amazon. I'll post up part numbers in the morning.
In the bottom 12v outlet tray, there is a factory harness plug for the adjustable pedals, park distance, and traction control. I'd guess no PPV has this option, mine didn't. I pulled out that hardess plug and hollowed out where it was locked in, so I could feed the USB through it. I doubt the USB would fall through, but threw a ziptie on just in case.
Everything works great, and this install kit came with a chime box.....which is actually a more pleasant tone than factory. And you can adjust the volume, which is pretty cool. LRM_EXPORT_123938426993749_20191006_202714414.jpeg LRM_EXPORT_123918677893288_20191006_202654665.jpeg LRM_EXPORT_123898403709181_20191006_202634391.jpeg LRM_EXPORT_123853143165605_20191006_202549130.jpeg
GM has a factory USB port that replaces one of the two 12V power ("cigarette lighter") ports. I don't see why I'd ever need two power ports so I changed my passenger side power port to the USB when I installed the Pioneer.
PPV12HOE
NC
Everything works great, and this install kit came with a chime box.....which is actually a more pleasant tone than factory. And you can adjust the volume, which is pretty cool. View attachment 231968 View attachment 231969 View attachment 231971 View attachment 231972 View attachment 231968
Looking good... my hoe actually has traction control...
PPV12HOE
NC
It looks like the usb he installed goes into the radio...
RichardCranium
RichardCranium
Head unit is an Alpine iLX-W650, its a 7" screen. All I really cared about was Bluetooth and AndroidAuto. Alpine also has a small amp that easily interfaces with this head unit to get a little more power to the factory speakers, which I might end up doing when/if I upgrade those stock speakers.
Here is the installation kit I ordered. It is a nice kit, included everything I needed to do my install. Also retained steering wheel controls as well, and can easily add a backup camera. Also includes a phone mic with along cord, and comes with a customizeable chime box as well. Would definitely recommend this kit.
https://www.amazon.com/gp/product/B01GP51ZF2/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Interesting!
I did not know that, have a part number by chance? I'll try to look it up later if not, no worries.
USB jack: 20944422
Cover: 20983937
You don't have to use the cover if you wanna save the ~$25. The only difference between it and the original one is it has the USB symbol on it. These covers are usually broken, so if you're missing one, this would be a way to fix that at the same time.
There's also a factory USB cable (22829189) that has the mini USB ends that lock into the back of the jack and back of the factory HU. I got this cable so it'd lock into the jack and I think I used an adapter to convert the mini USB to the regular USB for the back of the HU.
swazzie
