TahoeLTZ2007
- Joined
- Sep 13, 2011
- Posts
- 39
- Reaction score
- 7
Guess I better stick with the oem delcos.
Thanks Guys
Thanks Guys
Source?NGK apparently makes the AC Delco iridium plugs now so probably no real difference.
Source?
It wouldnt surprise me. NGK dealt with iridium early in the game because of them ***-o-neese ve-hicles I referenced. They kinda started using that tech earlier than the murican brands.
When I ordered my AC Delco air conditioning compressor, it came in a Delco box, and said "made in USA" on the box, yet it was a Denso compressor and it said "Made in Japan" on the compressor. But it was EXACTLY the same the the original that I removed from my truck. My OEM compressor was a Denso compressor. So I should have saved a few bucks and just bought a Denso compressor instead of the AC Delco, because it's the SAME DAMN THING!!!
Another time, I bought AC Delco spark plugs that said NGK on the plugs. Also, AC Delco belt tensioners are actually made by Gates. So save the money and just buy a Gates tensioner.
Greetings I installed a set of E3 spark plugs in my 05 Yukon Xl 4 wheel drive. The gas mileage increased by 2 mpg on the freeway.Any suggestions on double platinum vs iridium spark plugs for our 5.3L's? I can't find the OE recommendation in the PDF owners manual I have nor the AutoMATE online reference through my local library...
Go shill somewhere else and take your garbage ass plugs with youGreetings I installed a set of E3 spark plugs in my 05 Yukon Xl 4 wheel drive. The gas mileage increased by 2 mpg on the freeway.
