spindles + drop keys
tybardy
tybardy
everyone needs a Hoe
Gilbert Arizona
i know we have kinda *********** about this a little already, but IIRC, billsteins dont make drop shocks... does that make a difference up front? I think i will be fine out back with the extensions... just curious
tybardy
tybardy
Gilbert Arizona
from my understanding, you can get the toe correct but the camber will be hard, possibly imposible to get 100% corrrect.
Max
Mile High
Denver
Aftermarket cams ftw. My ucas are gonne get ripped out next month, easy fix for running keys.
tybardy
tybardy
Gilbert Arizona
since we are on the subject, i want to ask something about alignment
I had my truck aligned and the passenger side was a LITTLE out of camber, but otherwise perfecto... Now, both sides are jacked, toe is out and camber is ******... can a suspension "settle in" or something? Why did this happen?
tybardy
tybardy
Gilbert Arizona
by front end... you mean..........
i guess ball joints, pitmen arms, and a bunch of other expensive *********?
Max
Mile High
Denver
Yes. Balljoints will require replacement of the entire control arm as you can't press new ones into an arm that is all wallowed out. Usually it's just the pitman arm, idler arm, inner and outer tie rod ends. Parts were $500 my cost for the napa premiums.
bruh2125
