sputtering issue
412HOE
PITTSBURGH , PA.
OK , I talked to a tech at my local stealership and he says im on the right track , $70 for a re-learn after crank sensor change , but , $300 at min. to drop tank and replace seal on tank , and he says maybe dist. is ****** up...got a guy to do the tank seal wayyyyy cheaper , i'll go with him for that...cleanin the egr tomorrow , then droppin it of to get the tank seal done , the guy doin the tank says the crank and cam sensors where out of his realm .... at least he was honest ..... thanx for the input it helped alot , will keep yall posted..........
1999hoe
aka HOVERHOE
Massachoochoosetts
Cam position is easy its under the rotor under the distributor cap ...haven't changed a crank sensor yet but have also told its been easy to change
Dieseldr
