Squeaky noise coming from the outside of 2007 Escalade... what could it be?
yates ™
Resident Apple hater
Iowa
I wish mine would have been the rear :(
felixgun
felixgun
Lafayette, LA
Will be a pretty cheap fix for ya then :waytogo:
So if it's the wheel bearings in the front then you'd have to replace the whole hub and if it's the rear you can just change the bearings? How hard is it to replace the bearings only in a wheel hub?
Administrator
On the front you cannot just replace the bearings in the wheel hub. The bearings are packed in the hub and it's all one sealed unit.
yates ™
Iowa
What he says ^
The front is more expensive because it comes with a new ABS sensor
felixgun
felixgun
Lafayette, LA
Ah I see. So the rear hub is different and the bearings are easily accessible?
Administrator
Yes. The fronts aren't hard either. You just have to remove the wheels, brakes and take off the nut that's holding the hub on to replace it.
But yes, the rear is different.
yates ™
Iowa
I have no idea how to do a rear. I do not even see one on the site.
yates ™
Iowa
Then it will be harder to do then the front. I would take it somewhere felix
patniven
