ss bumper with hd grill??????????
that_slow_hoe
I am trying to install am ss bumper with an HD grill. I recently heard in order to install the hd grill you have to lower the bumper.. will I have to do the for the ss bumper as well???? And will there be a gap????
boozer
Wichita, ks
on mine, the one in the picture, i just cut about an inch off the bottom of the grille. you can also trim the cover. i didnt want to cut the cover at all. there would be a gap under the headlights if you lowered the bumperenough to clear the grille. i can shoot a close up tonight if you would like.
T
that_slow_hoe
Yes can u show me and what did u use to cut the bottom of the grill and hoe much of it did u cut
tobysan90
on mine, the one in the picture, i just cut about an inch off the bottom of the grille.. i can shoot a close up tonight if you would like.
Is there anyway you could post a picture of where you cut the grille at? I just ordered mine and would like to make it fit like yours, Thanks
boozer
Wichita, ks
i know the 03 silverado ss cover has the dip in the middle. dont know anything about the fit or if anything has to be moved or cut. i got this cover for really cheap so ill stick with it for now
boozer
Wichita, ks
Do anyone have pictures how to do this mod and what year is this grill
i do not have many pictures from when i did it but it is a grille from an 2000-2002 hd truck. all you need to do is take the hd grill, put a tape line removing about 1" of the bottom of the grille use a cutting wheel or whatever you have to cut it and i used a file to smooth it up.
Waylon19874
