Stabilitrak disable function?
PG01
Up here to the right
This does not work
Maybe not programmed in on ppv, idk...I do it constantly on my lt. Try this.....press once then release and that shuts off traction then, within a sec of releasing button push a second time and hold it and stabil should go off. If you can see it in dic display the minute you push button both will be displayed the traction will say off then stabil will go off as well. If you have the button and display in dic you should be able too turn both off
D95C0A51-A0BC-4438-B4B6-BAAB95ADBB6B.jpeg DB950B5A-DF14-4AEF-B123-5D460CEC4069.jpeg FDD21FAD-D5CA-45E1-BE85-795374742B17.jpeg
Shilohsho
I found a video on YouTube with a fella demonstrating how the traction control and stabilitrak affect the tire rotation and he showed the ABS fuse under the hood as the one to pull to get completely rid of the computer assisted programming. I pulled the fuse and the truck will spin as far as I want it to, in the rain. Dry pavement, not so much (3.08 gears in mine.)
I just have to put up with no ABS and the dash lights being on.
