ebxgsxr
ok, i have searched & read a couple threads where people have replaced their battery & everything was good. to give you some background.....idle for the truck seems very low. so low, it has stalled on me while sitting at a light a couple times. the truck starts back up no problems. but tonight, it stalled on my when i was trying to back up to get out of a friend's driveway. the RPM's go below 500 & i can see the battery voltage gauge start to drop. then it stalls. the threads i have read were saying to replace the battery & everything was good. but not the case for me. when i come to a light, most of the time, the voltage drops to right about 12 maybe a little lower. if i step on the gas to make sure the RPM is around 500-1000, the voltage comes up where it should & everything is fine. i would think the alternator is ok since when i press on the gas pedal to bring up the RPM's, everything is fine. but the new battery didn't fix it for me.
anyone know anything else i can check before i bring it to a shop?
