Guys - new to the forum and hoping to be an active member going forward.
I'm currently having steering issues with a 97 Yukon SLT with 205k miles (original owner, no accidents).
The problem initially presented itself as the steering wheel refusing to turn while parallel marking and under 5 mph maneuvering. The issue was intermittent, but when it did pop up it felt like I was going to rip the steering wheel off to make it turn even slightly. When it was acting up there was an audible clicking (1-2 times a second). No noticeable issues when going over 5-10mph.
Given that I'd only replaced the pitman arm previously, I started by replacing the EVO sensor, power steering pump, and high pressure lines - with new AC Delco parts. That still didn't do the trick, so I gave up and took it to an independent shop. They replaced the steering gear with an AC Delco reman unit and I had them put a new pitman arm in. They also replaced the PS fluid and presumably appropriately bled the system. When I got the car back, it was significantly out of alignment (straight down the road was at 2 o'clock) and I took it back and they aligned it for free.
Now that the reman steering gear is in, the steering is a lot heavier/harder to turn (before I could turn the wheel with a finger, now my GF probably isn't strong enough to drive it).
Given that almost everything steering related is new (all AC Delco parts) with the exception of the reman steering gear - any thoughts on why it is so much harder to turn the wheel at all speeds?
Improper Installation?
Bad Reman unit?
Any thoughts are appreciated!
Bad Reman unit?
