Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Do you have HID's? Try turning them off and see if that makes a diff. You may have to relocate some wires or get better wiring/ballasts if they are the cause.
aftermarket amplifier?? If so you need to ground the headunit better or to the same ground that you used on the amp. Or check the amp ground, needs to be clean and a good solid ground. IE frame etc etc
if not an aftermarket amp, just sounds like you need to ground the headunit better.
battery is new and connections are clean. As for the ground it is tied into the original ground via adaptor. Maybe I should take the ground wire pre adaptor connection and find a new ground.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
