Graystone_OG
the viking atomic sells are also for 2.5" ID springs. they would need a larger spring seat to use 4-5-6" diameter springs
I asked him how much preload am i supposed to set them up with, if he says crank it on down, i'll give it a try...the 900lb are only like 60 bux each i'm going to grab them and go for it
need to set a couple of bolts in the work bench for setting the preload up....kinda pain in the ass tightening the thin jam nut up on truck 1/8th of a turn at a time
Been watching your post and I was starting to get interested myself with the coil overs and how the springs are too weak. I started searching around myself and found this YouTube video:
Guy has 1200lb Hyperco springs but used the QA1 DS401 coil over instead since the spring is 8", so not sure if its compatible to the 403 that you have.
Here's there catalog with all the compatible springs. The 1200lb spring only comes in the 8": https://www.hypercoils.com/hyperco-catalog/
