Still bottoms out on 2/3 drop with 2" spacers...
Blazed
Accepting Donations
Ive been using the 5301 which is 07 up suburban spring (also 00-06 tahoe) the 5321 is 07 up tahoe yukon.
Why is it again that you prefer the Burban spring over the Tahoe spring?
I remember reading it but I forgot something about the spring rate.
Goodinblack
I Like Tacos
Dirty South
The Suburban is heavier then the Tahoe, so a stiffer spring for the Suburban.
The ride should be the same, as the extra weight offsets the additional stiffness.
Blazed
Accepting Donations
But I read somewhere I think tony saying he used the burb springs for everything.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
my bad just with kids. Yah thats right on springs
L
lynxnova
New Jersey
No not yet, I'm so frustrated with this cuz its only mild drop (2"/3") and I shouldn't have any problems...I will first try using longer bumpstops and if that doesn't work I will get the rear hardware kit and hope. That will work.... As soon as I put in the longer bumpstops I will post with more info..... I will like to thank all you guys for all ur info which really helps out a lot.....
Sent from my ADR6425LVW using Tapatalk 2
godoy
utah
Just get helper bags!!
I still have my bumpstop bracket with slim bumstops and don't bottom out with the helper bags
And I got a 3-5.5 kit
Sent from my HTC VLE_U using Tapatalk 2
mrfarb
