Stock Alternator Isnt Gonna Cut It
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Not to hound everybody but most people just want high amps and don't realize that it is possible to get good hi-amps as well as good idle power but you have to research power curve graphs and sometimes have to put out more money as well as draw a line from one manufacturer's unit to the next on how the performance would effect the individuals needs. Different pulleys help to.
retorq
Kingman AZ
The 95s had an optional 125 amp from the factory, you needed a different longer belt ... I bet you can get a higher amp rated alternator from Autozone with a lifetime warranty with the correct belt and less hassle. :D I bet they will even let you try it out in the parking lot before driving off. :D
QUYHMK
