Thanks.
I'd rather eliminate the chambers, and go with any straight-through design to remove the restriction, and add a little rumble. I was thinking of ordering something like this to replace the stock muffler:
<ul> <li><span style="font-family: Arial, Helvetica, sans-serif; font-size: small;" face="Arial, Helvetica, sans-serif" size="2">409 Stainless Steel<br /> </span></li> <li><span style="font-family: Arial, Helvetica, sans-serif; font-size: small;" face="Ar
performance-curve.com
That's identical to the one I had originally. It probably IS the same one, made from the same factory, etc. but sold in a Performance Curve box instead of the AP Exhaust box mine came in.
IMO, it's a win, especially at that price. Gives it some bark but doesn't require you to raise your voice to talk and doesn't drone.
This video kinda downplays the sound, but you might get an idea:
Made one a year later to compare "broken-in" sound:
Simple physics tells me there is some amount of mid- and upper-RPM power to be gained with a straight-through muffler. That's not to say that the factory one is a complete cork and that a straight-through muffler would yield anything you'd
really feel. But, as with pretty much any factory design, some performance was sacrificed to make the exhaust sound meet certain criteria in volume and note. The sound alone is worth the $57. Well, it'd be a more than that since you'd need about 6" of pipe to make up for the difference in length and if you're paying someone to install it for you. Still, it's cheap thrills.
Oh- as for the stock muffler's internals. This should be applicable to ours:
