Thanks for helping out.
I have a 2005 Tahoe that is making a slight grinding or scraping noise intermittently while braking at slow speeds and only during the last second or two before the vehicle actually stops. I also can feel a bit of a flutter or shudder in the brake pedal with the noise, and it all stops if I let off the pedal so it appears to definitely be in the brake system not a wheel bearing. I just replaced all the brake pads & rotors but it still does it, so it must be something else. Also, the brake fluid reservoir is full.
Any suggestions?
Air in the line ?
Bad calipers ?
ABS engaging ?
Thanks again
Any suggestions?
Air in the line ?
Bad calipers ?
ABS engaging ?
Thanks again
