Strange Issues. Please help a brotha out.
as long as that stabiltrac/traction light is on the cruise control wont work. It's a safety thing because it's getting erratic or bad data from somewhere so cruise is disabled.
S
SDWallhanger
ok, so yesterday check engine light came on as well with error code P0335 Camshaft Positioning Sensor.
Now what do you ll suggest. Camshaft Positioning Sensor or plugs and wires or both??
You're in the 2021+ section. Take it in for warranty work.
S
SDWallhanger
Ok, will check it tomorrow and let you know.
Thanks for your help. Guess I will get new plugs and wires while I'm there.
No other codes, but yesterday check engine light came and a blew code P0335 Camshaft Positioning Sensor. So waht yall think now. Camshaft Positioning Sensor or Plugs and wires or both??
S
SDWallhanger
Mmm, ok. Going to repla e plugs and wires and then will update.
Ok so no and brake codes and check engine light no2 on. Blew code po335 Camshaft Positioning Sensor. So what y'all think now. Camshaft Positioning Sensor or plugs and wires or both??
GMT800 SUV/Trucks
Welcome to the forum from Oregon
@Fless he said in first post was a 2007 GMC XL Denali but was in the wrong section. Like has been said by @wjburken and @Bill 1960 said, complete codes are needed.
Also been said, the front likely has a bad hub bearing or two and when replace, for the love of God, don't go cheap. get Timken or AC Delco. May also just have some wires/connectors causing the problems at those wheel speed connections. If you have no idea on the age of the plugs and wires you again can get some good quality AC Delco parts for that but the plugs may look great. Pull one or two on each side and post pics here for recommendations. You will get there eventually with the fix on these problems.
May end up with one of these too. https://www.rockauto.com/en/moreinfo.php?pk=993793&cc=1433459&jsn=2045
S
SDWallhanger
so dont replace Camshaft Positioning Sensor. Replace Front Hub Bearings instead?
Filvanz
