Stuck at the gas station
dubyagee01
My starter did this exact thing. Random no starts until it left me 120 miles from home. AWD made is super to swap.
retiredsparky
A common cause for this no-start is a switch that is mounted to the transmission. It looks for the transmission to be either in park or neutral. Moving the gear shift selector from park to neutral will sometimes allow the engine to start if the park switch position is intermittently (or permanently) failing. (Foot on brake if doing this). If this fix doesn't work, the ignition switch is the likely problem.
Warriorpluto
Why was it so ******* AWD? I have an 07 Denali. I bought an low mileage starter for a backup just in case mine acts a fool. What all did you have to to?
SlimTheTech
