Sub Box Ideas
T
Tahoe_96
Two subs is going to be more than just adding low end. If you just want to add a little bass, I would take one of the subs, throw it in a sealed box and toss it in the corner that will be out of the way. That will be the most cost feasible option. But I have a feeling you will want more bass. Those aren't bad subs so you have a lot of options. Do you have an amp yet?
Sent from my PC36100 using Tapatalk 2
Yeh I have an amp and all the wiring just no box yet
ParacordPaul
Hey Guys,
Do a search on fleebay for 99 tahoe sub box and you'll see a box that fits under the rear seat that holds 2, 10" subs. I have one and it fits good, about 100 bucks shipped. Only problem is the mounting depth is only 4 1/2" but you could use a couple mdf spacers if your subs don't fit.
You can also do a google search for audio dynamics design, that's where my box came from.
Paul.
_Dylan_
STAY FROSTY
hey those wheels look very nice on your obs!!! Are those 'Titan' as in Nissan Titan stock wheels? Thanks and good luck with your subs!
Thanks man! :) They are 18s off a 2012 Nissan Titan. I found them on craigslist for $100. There are some more pictures in my thread.
ssrado85
Galveston
Sorry for the crude drawing all I had was paint, but this is what Im doing in my 96 2 door. 3 L7 12's ported almost 10 cubic feet of airspace.
T
Tahoe_96
I would love to do something like that but between the wife kid and dogs i need my cargo space...thats why im just sticking with the two 10's
im gonna take the panels off the barn doors ....do yall think i can put them there
ssrado85
Galveston
you could prolly squeeze something in there but there is alot of stuff latch wise to get around, I would make a box or two that saddles the fender well you wont loose a whole lot of space. :shrug:
97srad750
Lexingon, SC
Hey Guys,
Paul.
Anyone else tried one of these boxes? They make them in a 8, 10, and 12. I thought about getting one and trying some of the MB Quart shallow mounts. Maybe some other type of shallow mount.
BigDaddy13440
Rome, NY
How much of the quarter panel did you have to cut out to make this possible
I cut the entire inside panel out, from the rear corners up to where the rear seats fold back to. I made the top and mounting face with 3/4" MDF to give me the approximate size I wanted, and fit pieces of MDF inside the cut fenderwells to make the sides. The back wall of the enclosure(s) is actually the outside skin of the fenderwell, with something like 6-8 layers of fiberglass mat stiffening it, and sealing it to the MDF of the box. All told, I've got about 2.4 cu ft per enclosure, which equates to about 2.0 cu ft after port and driver displacement, perfect for my old-school Celestion AD15-H's.... that's right, 15" subs in 2.0 cubes, can't do that with ANY of today's long-excursion subs.
I recessed the subs into the enclosures, so that I could make covers out of some 3/8" plywood to protect them. Drilled a bunch of 3/4" holes in a grid pattern to allow for air movement, and covered the cover with some acoustical carpet.
I've also got a pair of Powerbass S-10 subs in my center console I fabbed up, firing downward. I made brackets to move the seats out and back 1 1/2", I now have about 14" between the seatbelt mounts. Made an amp rack to fit on the floor from the dash to the back of the front seats, I have 3 amps mounted on it. The Powerbass subs are in a 2.0 cu ft enclosure (I think??), and fire downward at the amps, with about 1/2" of clearance between the cones at max travel and the amps. I had enough room to do a flip-open lid in the top of the enclosure, I can store about 20 CD's, and all my paperwork for work (as a contractor). This enclosure is squared-off, but the front face slopes down towards the dash, leaving me access to the power ports.
Been in my truck for about 4 years now, still going strong.
My next truck will be a Suburban, I plan on doing another center console the same way, but will do it with fiberglass and body filler, I want it to have a more rounded look to it.
