Suburban 2500
puckhead
puckhead
CO
What do you guys think of the 2008-2013 with higher mileage? Does this version handle miles well?
intheburbs
SE MI
Well I can offer one data point...
I bought my 2008 2500 in 2013 with 106k miles.
I drive it hard, and beat the crap out of it towing - heavy travel trailers, into the Rocky Mountains. Probably 20k miles of towing at max GCWR (16,000 lbs). On one trip, I was spinning the engine so fast for engine braking - 6k rpm - that I spun the A/C belt off its pulley without breaking it. I also drove for Uber for a while, probably 1000 trips.
It now has 202k miles, is still all-original, and dead-nuts reliable. I haven't even had to change the brake pads.
I wouldn't hesitate to load up the family, hitch up the behemoth and take a 5000-mile road trip to Yellowstone.
I've also spent about $300 in repairs over the last 7 years. Total.
puckhead
puckhead
CO
Well, that's pretty damn good! Sounds like these motors are pretty good. I am still looking around but the more affordable ones are fairly high miles. Mid 100's to just under 200k. There's a few with less but the cost is more. Just looking for the perfect one right now.
calsdad
Not sure I understand what you mean by what kind, @wjburken
As for year, I guess the newer the better. Just looking for something that can haul a good amount but is still good on the highway ride wise. Not looking for economy lol.
The 8.1L with 4.10's sounds like fun!
I had a 2003 Suburban 2500 with the 6.0L gas engine. I now have a 2010 GMC Yukon XL 2500 with the 6.0L gas engine. I thought the 2003 actually rode better than my 2010 - but that could have been because it had Michelin tires. The L96 6.0L gas engine in the 2010 has more power than the 6.0L that was in my 2003.
I never really paid much attention to the fuel economy in the 2003, but the 2010 does about 14mpg - with mostly highway miles. I tend to drive about 75 mph all the time though.
The 2003 truck was a definite rust bucket - so far - the 2010 seems better. There were a number of improvements in regards to rust mitigation on the 2010 that didn't exist in the 2003. The fuel lines, brake lines - etc - are all coated on the 2010. They weren't on the 2003 - and they ALL rusted out on my truck. A good part of the reason why I got rid of the 2003 - was that the thing had gotten to the point where it was either going to need a LOT of work to keep it from completely rusting out - so I decided to sell and get a truck from the next gen. I liked the 2007-2013 body style better anyway.
One thing the 2003 did better I think than the 2010 - was the the second row seats on the 2003 folded flat - they don't on the 2010. This made the 2003 a little bit better for hauling pieces of plywood than the 2010 is.
The frame and suspension on the 2003 and 2010 truck are pretty much EXACTLY the same. The frame carried over from the 2003 generation to the 2010 generation. So parts are somewhat interchangeable.
As somebody already mentioned in this thread - the GMT800 (2000-2006) trucks with the 8.1L engine - had a 12,000 pound tow rating. That means the frame is good for towing 12,000 pounds. The sticker on the door will not say 12,000 pounds unless you've got the 8.1L engine, but the frame is good for it.
I think this is important to keep in mind - because the hitches on the GMT800 and GMT900 trucks are barely good for the "normal" tow rating of 9900 pounds IMHO. If you look thru a number of the GM forums and some trailer towing forums - you're going to find people complaining about the factory hitch on the GMT800 trucks actually ripping off the truck. I swapped over hitch on my 2003 over to a 16k rated hitch. On my 2010 I built a custom 16K hitch for it - because nobody specifically made a "standard" style frame mount larger capacity hitch. ( the factory hitch is in the bumper reinforcement bar).
Why do I mention all of this? Because IMHO the tow ratings of the 2500 is cut back somewhat from it's true capabilities. As I said - the frame is good for 12K. If you look at a 2500 series pickup truck from say 2010, the trailering capacity of an crew cab/long box is 12,400 pounds - with the exact same drivetrain that is in the 2500 series SUV.
So my opinion is - based on looking at ALL of the various ratings of the different mechanicals with the 2007-2013 2500 Suburban/Yukon XL's - is that they're probably capable of towing 12,000 pounds.
The door sticker just doesn't say it. And therefore it wouldn't be "legal".
Depending on what state you live in - there's always the possibility of doing a diesel conversion. If you were ever going to think of doing that - I'd go for a GMT900 truck.
calsdad
One of the things I didn't like in either my 2003 - or the 2010 - was the braking. In the 2003 I upgraded all the brakes when I had to do them over with cryo-treated rotors and the best Hawk pads I could find. That made definite improvement.
On the 2010 - when it came time to do the brakes over - I did a serious upgrade and installed Wilwood 16" rotors with 6 piston fixed calipers. That made a definite improvement in the braking. But I've been driving this truck a lot in rush hour traffic and had a few close calls with people cutting me off and then jamming on their brakes.
calsdad
The last year for the 2500 Burb was 2013 - they are getting hard to come by - most came with a 6.0
Pretty sure that ALL of the 2500 series Suburbans and Yukon XLs came with the 6.0L gas engine. On the later trucks (I think after 2009) - this was the L96 engine. I can't remember what the model number was of the 6.0L engine in the earlier model years.
calsdad
This is slightly off-topic, but 2015+ you can buy a Suburban 3500HD as long as it's for a fleet. There aren't many out there, but occasionally you can find one on cargurus or similar.
The factory tow ratings on those are abysmal. Not sure exactly why - because with the 3500 designation it should be able to tow well.
calsdad
Look at the condition of the body and frame. As long as it's not very rusty - all the rest of the mechanical stuff can be fixed.
At 120K miles so far the drivetrain on my 2010 has been great. No problems at all.
I rebuilt the front suspension completely about 15k miles ago because it was starting to wander on the highway and was getting annoying to drive on longer trips. After the rebuild it made a big difference.
rzabel
Redmond, Oregon
I hadn't heard that about the hitches, but always wondered just from looking at it. It definitely looks like the weak link. I put a Curt front receiver on mine and it looks beefier than the factory hitch on the rear. I think I'll look into an upgrade there, thanks.
norcalboon
You and a bunch of others - especially now that everyone is camping, if you find a good one act fast!
BlackBettyBurban
