Successful sound deadening for headers?
L
ls1frc
It is most definitely not. The best sound deadener you can buy right now is Resonix. Second place goes to Dynamat Xtreme. Other than those two, don’t bother.
Ok I won't bother installing it then. Do I even need the CLD under the MLV then?
91RS
GA
Honestly, for what you’re trying to accomplish it may not be worth it for you. Deadener/CLD is mainly for panel resonance which is lower frequency and the header noise you want to block is higher frequency. The main thing I would consider is not wanting to do it twice, especially if the Luxury Liner is adhered to the floor. It is my understanding that doing the floor with CLD doesn’t get the same results as say the doors or roof since most vehicles have at least a little deadening on the floor from the factory. The Luxury Liner is probably the right product for you but I might go ahead and put down a little CLD under it. Not 100% coverage though.
I’ve been going back and forth on what I want to do to mine. I wouldn’t mind blocking some road noise but I don’t really want to block any exhaust noise which isn’t possible to block one and not the other. Even if I block road noise there’s still wind noise that can’t be fixed. I was planning on doing something when I replace the carpet, which I haven’t even bought yet but need to do soon before it’s discontinued. I do really want to do the roof but that’s a lot of real estate so it won’t be cheap.
L
ls1frc
Thanks. From what I read, full coverage isnt needed anyway. I think ill buy the bulk kit and use a few squares on the floor under the luxury liner. Then use the rest in each door panel and be done with it.
I am also leaking at the ball socket connection and every single slip fit. Im confident I can fix the slip fits with the 750 degree RTV but I never had any luck at the ball socket connections with it.
L
ls1frc
Was gonna put the stock exhaust back on and be done with it..
Then I saw how TINY the pipes are. This will probably lose 40+ hp. No way man lol.
91RS
GA
Easily. I found a video on YouTube when I was deciding if I wanted to buy headers and I think it was LMP did a before and after dyno and just long tubes and tune gained 50whp on an otherwise stock truck.
L
ls1frc
Yup! I just hate the resonance, driving me nuts. I hope the mats help!
L
ls1frc
Ok so one sound is "solved"
In addition to the resonance, my cammed valvetrain is quite loud in the cabin around 2k rpms. I put in Redline oil, which is a true ester based oil with more zinc and tons of moly. I can't believe it, but it actually solved the noise. All I hear is the resonance from the headers now, which is even more pronounced now haha.
Next week the mats will get here. Crossing my fingers.
91RS
GA
The Redline oil is the bomb. The valve train in my SS was so loud after I did the cam I thought I messed something up. I’ve changed both trucks over to it now also. I like the header racket though.
L
ls1frc
Man I couldn't believe it. I must have spent 200 dollars at walmart over the last few months trying different combos. This is the first one that made an audible difference.
I will do 5w-30 summer/0w-30 winter and do 6 month OCIs in each. Which filter are you using?
91RS
GA
I do 5W-30 year round here in GA, not sure where you are. I use the Royal Purple RP-48. When I researched oil filters last it was one of the best synthetic medias.
I want to change my transmission fluid to Red Line also but it has 150k miles on it and supposedly has the "crappy" early seals since I have an 08 so I'd just hate to spend all that money on new fluid and then something go wrong with the transmission and I have to buy it again. My other truck is a 12 but has 187k on it now so same story there just because of the mileage although that transmission shifts better than my 08.
TheZTahoe
