After returning from a long trip (350 ish miles), I discovered a puddle of coolant under my car the following morning. I might've lost about a cup of coolant here. The leak appeared to stop and has not lost another drop since the big loss. The next day I inspected the car above and below to find no apparent spots where it could've came from. The radiator was dry on the outside, water pump looked good, all hoses were dry, and heater hose connections were dry. I did notice i have a small oil leak from the valve covers but upon removing it, there was no gunk inside so no indication of coolant seeping in through the head bolt holes. I do have the 862 head castings which are apparently better than others of my year. I started to think the heads were cracked although I never overheated at any point during the trip or afterwards. I did find that the coolant dribbled down the driver side exhaust manifold and got charred below the cat on that side. Kind of at a loss of words here for what it could be since I haven't lost any more coolant. Maybe a bad head gasket? No white smoke when driving that I could tell...
