Summit Big Break Kit???
ATL
there was a set of front and rears in the for sale section and i dont think they ever sold. search that forum
01Konvict
Boats n Hoes
Raleigh/SML
Just swap to GMT900 front brakes and hyrdoboost, use slotted rotors and good performance pads. It will through you out of the seat like it does on mine.
jESse
i like cheese
michigan
i've been wanting a big brake kit. anyone know if that will fit under 18's?
WildBill
I would take the bigger disks over the GMT900. The kit is 14" on all corners, GMT900 are 13" front only (correct me if im wrong).
I have been looking at:
http://www.autoanything.com/brakes/61A3158A0A0A3107156.aspx
by SSBC. I would also prefer this brand over Summit's. though they look the same. Add some HAWK pads and you'll be golden. Maybe powder coat the calipers and cages before installation.
01Konvict
Boats n Hoes
Raleigh/SML
14" on all corners is great for brakes but convert to hydroboost first. It really made night and day difference as far stopping distance.
Ninety5PoloZ
Ninety5PoloZ
Wisconsin
Summits kit is probably SSBC, they are good for putting their name on things other people make. Kind of like their throttle bodies that come in a Holley box.
The reason I was looking at this kit, is the fact that I can go back to stock rotors in the winter with the stock wheels, then in the spring put the big brakes and wheels back on without having to bleed the brakes or do anything crazy. Sounds dumb, but its better than trying to run 22s in the snow in Wisconsin
ornelasa35
Might want to do more research I think i have seen that same kit for about 400 bucks can't remember uf it was summit or jegs
WildBill
Ive looked all over and havent seen it for that little. If someone finds it, post a link!
Roscoe2352
