Surging at Idle
blondie70
Truck is surging at idle....from almost dying to about 700 and back and forth....but not all the time.
It has the cam in it now and has been awhile. I took it back to the tuner and he checked it out and says it runs great and sees no problem....because it never did it with him....ha ha
I think I will try the "throttle body relearn" and see if it helps. Everything looks good and it runs great at speed.
Anyone got any ideas ? Thank you.
11bravo
Las Vegas
I don't know what all you have done to it, but....surging can be throttle body, throttle body sensor, fuel pump and/or filter, MAF, dirty air filter, and other things I am not aware of. The re-learn is a good starting point...
j91z28d1
surging at idle with a cam is pretty text book tunings. needs more in the airflow table I believe it's called.
cleaning and resting the tb and maybe cleaning the maf can help. but I think you're going to have to figure out how to get it to do it in front of your tuners, or at least get a data log of him to see.
Tna4n2
