suspension opinions and facts
wolferine358
Hello fellow members,i wanted to know whats the best handling for an 04 denali,thats including sway bars,control arms,sway bar inks and other parts that will tighten up my suspension,i have autoride so I don't want to interfere with that change.
what website can I get these parts from and name brand can I use,that will stiffen up my stock suspension.thanks for any input:roflbow:
wolferine358
wolferine358
no replies.i know you tyf guys are very knowledged,any responses wold be appreciated.:roflbow:
Multnomah Falls
Mostly, to stiffen up, just start installing polyurethane bushings and larger diameter sway bars when you can. Least expensive and does stiffen the ride.
wolferine358
wolferine358
Thanks fiatdale , and raideron I'm going to put bigger sway bars, end links and bushings to start the process
Maic
15 Suburban LT / z71
Houston, TX
x2 on the sway Bars.
One of the first thing i did. What really helped was installing my non-existing bump stops or "jounce stop's".! Don't know what year you have, but it may be something to look into.
Some info here :http://www.tahoeyukonforum.com/forum/showthread.php?t=64186
gl
lgksser777
