Levin37
07 Yukon Denali. Factory steering wheel got a dent in the leather and it started smoking whenever I turned on the heated wheel. Ordered another OEM wheel and swapped it in (and then back out as I ended up getting a wheel with everything but heat). After everything was reinstalled and battery reconnected I got no display on my stereo, no clock, nothing. Rechecked all connections in the steering wheel, everything good. Checked all fuses, good. Pulled the positive terminal off for another 30min, no change. Decided to pull the head unit out and checked power behind, 12V, ~14V when running and another wire has 8-9V which I think is the dimmer, no ignition power wire that I can find. So if there anything else I can try? The unit doesn't have a fuse on the back, do I have to or can I reset the BCM?? I have sourced another OEM deck locally at the wreckers for $200CAN but it will cost another ~$150 to have the dealer reprogram. Would like it fixed as cheaply as possible, so aftermarket deck isn't really an option right now. Thanks in advance for any tips. Cheers.
