Swapping exhaust on a Denali 6.2: who here kept their old one/how?
TrueAt1stLight
Minneapolis
I’m swapping the exhaust on my 22 Denali and wish to keep the factory exhaust should I decide the GM Performance exhaust is not for me. The dealer said they’re not sure how they can do that as the factory exhaust is so long they’re unsure how I’d transport it. I asked if it’s as simple as cutting the pipe so it takes the size down in half and the sales associate said she’d check into that. Anyone here keep your stock exhaust and if so, what did the tech do to make it a manageable size yet still able to be installed back on? TIA!
you would need to either shove it in the back of the new truck and likely smudge things up, or load it in the back of a pickup or have it cut, gm will not sell any "pieces" of exhaust only whole parts so if you have it cut choose carefully so a 3rd party shop can weld it back together, gm will not weld anything.
wsteele
I think I would just bring a battery operated Sawzall (or just a hacksaw and some elbow grease) when picking the old setup at the dealer and cut it on each side of the long runs in front of and behind the muffler (on the straight parts not a curve). That should yield three pieces that will fit inside the cab with the seats down. Bring some drop cloths to protect the interior from all the crap. If you don't like the sound just take it all down to a muffler shop and they can reinstall the stock bits and weld it all back up.
You also might drop by your favored muffler shop and ask them if they have a suggestion of where you might make the cuts to make it easiest to re-weld.
Frankly, I am surprised they don't cut the stock one to get it out. All the clips I have seen entail a cut before/after/both to make it easier to get out. Although, most of the clips I have watched were with the Silverado and Sierra trucks.
vince7870
Can you post thoughts once done? Good or bad
T
TrueAt1stLight
Minneapolis
Thanks very much! That’s great info!
mikew2069
You can definitely cut it into two or three pieces, no problem. try to do it in an area where the pipe is round and not crushed.
the whole system is made to bolt on/off, it has to be unbolted to get the transmission out & in
wsteele
Got it. It must be a little different on the pickups, as every video on Youtube I have watched, they cut the tube somewhere past the muffler (a few cut it on both sides) when removing the stock exhaust. It looks like it has to do with getting the tube that leaves the muffler out as it goes over the rear axle.
Anyway, the point remains, if any of the pieces are too large to get into the cab, cutting one of the straight runs won't present any major problems if he decides to put it back in (pretty unlikely of the sounds I have heard on the clips are any indication of the upgrade).
If you do cut it, before you do, take a marker and make some alignment marks so when it's welded back together it can be clocked properly. It's probably obvious how it should go, but cheap insurance.
Rtoutwest
