switches
ktmhans
Connecticut
So im trying to figure if this is an easy fix or not. 04 tahoe LT i open the door locks from either the driver side or passenger side and nine times out of ten the rear doors dont unlock. They will lock but not unlock. Yesterday i went to open the skylight and the switch didnt work. I tryed it 2 more times and on the 4 th it opened up. I was like shit it better close! Luckily it did, but what if it doesnt.
This is the most challenging truck i have ever owned!
Rivieraracing
I'd be checking harness connections for the switches and make sure they are clean and making good contact! Switches can get worn out but I'm guessing it's a bad connection on the lock switch and could either be a bad connection or a worn out switch on the sunroof!
K
ktmhans
Connecticut
Are these inside the door? As simple as prying the whole unit out of the door. I think that was how my obs came out. Also i cant figure out how to save the driver 1 settings. I go into the dic and do all the settings for driver 1. Seat mirrors rado and somehow it doesnt save it. Manuel doesnt give any help either.
Thanks for the help
big_b_in_PA
Billy Badass
Central Pa.
Do you have the memory buttons on the drivers door? If so set everything where you want it to be, and hold down the #1 button until you you hear the door chime. That should do it. If you dont have those switches, I have no idea how to set he memory.
Good luck!
K
ktmhans
Connecticut
Good luck!
SWEET! Why the heck doesnt the manual say that. I'll give that a try when i *** home. Thanks
Rivieraracing
Big B is correct, but mine doesn't make a beep or chime in my truck when I set the memory seat but if you at least hold it in for a couple seconds it should do the trick!!
As for the switches, the drivers window switch just pops out, just grab the side that faces inside the truck and lift up, there are 2 snaps there. As for the sunroof switch, just take out the screws on the assembly on the roof where the switch is at and I think it will pop off of the roof at that point, there you will have access to it!
ScottyBoy
Shreveport, La
Actually, on a 03-06 you have to take the door panel off to remove the switches from behind. They only pop out on the 00-02 trucks. 03 and up they are screwed in from behind. You will break it if you try to just yank it off.
K
ktmhans
Connecticut
Cool i dont know why i didnt think of that. Guesse i thought it was all just cintrolled drom the dic. And the steering wheel buttons.
Rivieraracing
That's good do know, thanks for the clarification on that, would hate to have someone take my advise and mess up their crap!! :Handshake:
Another thing GM HAD to change!!:Plugged:
K
ktmhans
Connecticut
Wow cant believe i missed this post. Thanks for the info! Hopefully i dont break the door panel clips.
This new DST sucks, i cant get anything done in the dark!
