System starts with this warning ⚠️
Sean669
Hi all
On a 2023 Tahoe, is there a way to prevent this warning ⚠️ from coming up every time?
Thank you for your input
JTGZ71
I don't get that warning message at start-up. Are you logged into Google?
BigdawgR6
I have this issue as well but will try this:
"I found this, not so much a fix but the message is not popping up any more.
settings > apps and permissions > show all apps > google assistant and then clicked disable."
NELLY1947
Hi all
Is not the whole idea of having Google voice. So you don't text or touch things. Up here most provinces have a minimum fore of 1000$ just for touching your phone.
BigdawgR6
So when I disabled the app, I was no longer able to use Google Voice. Instead when you push the button to voice a command, Siri comes up. This is only useful if you use Apple Carplay. Though, at the end of the day, I turned it back on to use the full integration.
jackkk
