Tahoe DRL Blinker Switchback LED ReWire
KiLLerSpyder
Northern California
In this image the wires that look green with white stripes, did you cut that wire in half and strip it just to wire it in? Hard to tell where those are coming from...
Do you have or can you make an actual wiring diagram or even a rough drawing of all the wires, just not getting it.
Mester320
Fort Myers, FL
The striped wire is cut in half so you can include the resistor and blue wire from the new DRL socket inline with the striped wire. Does that make sense? If not let me know and I can try to explain better. I just did this and will have the bumper off again this weekend I will try to get a full pic of the back of the light but everything is taped up so i will do my best.
Mester320
Fort Myers, FL
I want to thank DWebPro for the great write up. I just did this mod and this thread made my life so much easier! I used all of the same components as DWebPro except for the resistors and switchback leds. I wanted 5000K instead of 6000K.
I purchased these "3157 Switchback LED Bulb - Dual Function 60 SMD LED Tower - B Type - Wedge Retrofit" from superbrightleds.com. You can just click on the link. These are a pure white light, no yellow or blue. I wanted to match my 5000K Morimoto HID lowbeams. I could not be happier with my choice. They are more pricey at $15 per bulb but they are BRIGHT!
Also finding LED fog lights in a true pure white 5000K for our trucks is much harder than you would think. I bought the OPT7 plasma bulbs but they were way to blue for my liking. So I searched and searched until I found a set on VLEDs and they promised me they are a pure white. They are in the mail now so I will post a pic this weekend once they are in.
If you have any questions I would be more than happy to help out.
Mester320
Fort Myers, FL
Here is a picture comparing stock to the new switchbacks. Such a great mod!
I will get a few tomorrow of the finished product w/ the matching fogs.
KiLLerSpyder
Northern California
Just orders my new headlight canisters, switchbacks, sockets, and resistors / Cant wait...!
Once I have the frontend off I should see the wiring as explained, be on the lookout here just incase.
I ordered them ground (Spent tons of money lately on the Tahoe) staying cheap
KiLLerSpyder
Northern California
I just realized I didn't get these - (2) Epoxy Rectifier Diodes #276-1141 By RadioShack, are they a must? I did get the resistors however, I've read directions in other post and those weren't mentioned. I just read here that may not be true..
I'm afraid to say I'm still confused on the wiring
Mester320
Fort Myers, FL
A little delayed but as promised here are a few pics. I will try to get a few more if needed they are just so bright the camera has a hard time focusing at night. I will get some day shots maybe tomorrow.
Stock fog bulb on left, new 5K VLED bulb on the right
Both VLED fogs and switchbacks
Ground beam pattern w/ switchbacks on(note headlights are not on)
Beam pattern w/ switchbacks on(head lights are not on)
DWebPro
DWebPro
Stevenson Ranch, CA
Can you post a link to the fog bulbs? Your 3157 bulbs look a lot brighter than mine and I think I am going to swap out mine for the bulbs you have. Did you use resistor and diodes as well?
To my knowledge yes the are required, not sure why...
Champ74
