Tahoe Fog lights
Kpwweb
WalleyeMikeIII
Sunny and Snowy Minnesota
I installed the right side yesterday. I got the model that mounta above the recovery hooks, so cutting was required. See pics. Sorry for the long process
The look great, but pretty much rendered the tow hooks useless, or at least at high risk of putting your fog lights in harms way if you were to use a shackle or a metal hook.
With a strap with loop ends, you may be ok.
Kpwweb
There is a little more room than what shows in the photo, but it is somewhat crowded there as well. I was told they may be working on actual clevis hooks, like the at4x has. I should also say they have the same setup that snaps in the grill instead of mounting above the tow hooks, leaving that area completely stock.
h0m3w3CkeR
Virginia
Has anyone purchased these for the RST or similar models? Considering these since its the only option I have at this point.
Tried installing some in the same area, and on the passenger side there is a small short range radar sensor an inch behind the panel.
Stevemo70
