Tahoe Offset and Backspacing
Damien
TN
I'm currently running 285/45r22 tires and wanting to swap up my wheels. I've been looking at the KMC slides but there are two options on the 22s:
1. 15mm offset 5.84 backspace
2. 38mm offset 6.75 backspace
Which of these would fit best without rubbing? I don't want them sticking out either.
massivespl
I'm not mean, I'm honest.
Michigan
Neither should rub with that size tire. I'd get the 15mm offset
nharkey85
Alabama
Assuming youre starting with factory wheel and tire....
15mm offset will give you 1/2" further out than stock and 1/4" further in than stock.
38mm will take all the extra width and push it in plus some, just over an inch total closer to frame.
heavy02
