Tahoe Owner From Hell Paso,TX
915_Tahoe
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
When did I ask for help on this thread, cause I didnt.
IF THE CAPS BOTHER YOU THAT MUCH THEN DON'T READ MY POST SIMPLE AS THAT.
When caps are off I post from my phone.
WHEN CAPS ARE ON I POST FROM WORK, WHICH IS HOW OUR SYSTEM AT WORK IS.
915_Tahoe
915_Tahoe
HELL PASO, TX
So had a great haul this weekend @ the salvage yard.
for the HOE
Esky roof rack w/ cross bars
Esky shifter w/o the chrome cover (cover wasn't there when i took it off)
Both rear door lock actuators
Drvr rear door panel
Spare sub box
Drvr side inner bottom molding/seal strip
EBCM
for the Silverado
Drvr front door with window and regulator
Pass window
915_Tahoe
915_Tahoe
HELL PASO, TX
So i have done several thing to the truck just have not yet posted.
Whats new:
new set of tires for the stock 16's
full front suspension rebuild
front/rear shocks
new set on black head/turn lamps
L.E.D. tails
L.E.D. 3rd brake light
escalade roof rack
replaced driver rear door panel
replaced both rear door lock actuators
replaced the driver upper/lower leather covers also added a new bottom seat cushion
amp bypass
amp to power the upgraded stock sub
rear radio pocket delete out of a Buick rendezvous
bug deflector
removed fan clutch and shrouds
OE battery terminal covers
IN THE PROCESS AS WE SPEAK:
water pump replacement
OE updated thermostat w/housing
OE front main seal
added a OE harness from the fuse block to front of the engine
waiting on my ECM to arrive to re-install
OE e-fans going on
fuse blcok w/ provisions for e-fan fuse block
NEXT ITEMS TO INSTALL:
rear carpet with the tracks for the 3rd row seats
escalade shift lever
will gets pics up soon
915_Tahoe
915_Tahoe
HELL PASO, TX
What's your on/off temps? Can't wait to do this!! Where you put the oem relays and wiring? I bought the oem fuse box to do it.
Not sure on the temps, just sent it to the guy told him to turn then on.
Ran the factory harness as it would have been on the 05-06 models. Since mine is an 01 I had to use a relay for the ac, I purchased a novita relay and the matching pig tail to go with it. I'll get some pics of it in the morning. Also got the fuse box when I pulled the harness and fan from my brothers wrecked sierra.
Since mine is an 03, will I need a relay for the ac? I did get the complete harness including the relays--that 2nd half of the harness that attach to the fuse box-- from an 05.
ScottieGirl
