Wow, a lot of negativity in here. The reason the caps are on is I post from work so the system is setup that way.
BULL …. SHIT... That's not the way systems or keyboards work. Amazing how you somehow figured it out for this post. Even on this post you could have just grown up and said OK. That maybe you didn't realize it was a problem or some other excuse. Instead you doubled down, and came up with another lie.
SO AWHILE BACK I PURCHASED A PIONEER STEREO WITH SPEAKER COMBO FROM WALMART.
CAME WITH HEAD UNIT 2 6x5 SPEAKERS AND 2 6x9 SPEAKERS. I INSTALLED ALL BUT THE
6x9'S AND LEFT THE REAR ALONE DO TO THE 6x9'S WONT FIT. THE OTHER NIGHT I MODIFIED THE ORIGINAL SPEAKER BRACKET TO FIT THE
6X9, GOT IT TO WORK EVERYTHING CLEARS. I JUST NEED TO TRIM THE DOOR PANEL FOR THE SPEAKER.
View attachment 213360 View attachment 213361 View attachment 213362 View attachment 213363 View attachment 213364
Or are you going to try to triple down and say your "system that writes in all caps", knows to use a small x when writing 6x9's, but not 6X9??
Or perhaps this one.
What I did at work yesterday , instead of doing my actual work. Lol
Where you didn't use caps, along with a couple other posts, but then later went back to it..
Clearly you're lying....
We need to get over ourselves?? You're the one who couldn't go-along to get the help you were asking for. I'll bet if I bother to search, this isn't the only thread someone has mentioned it to you. Were trying to help, and you are making it harder for people to do so. Not sure why that is so difficult for you to understand or for you to try to cooperate with the rest of the ENTIRE ******* INTERNET for the purpose of having improved communication.
We can keep this going or I can see that you have stopped using all CAPS for atleast a couple of petty posts. So lets see if we can just move on.
Where is Chicos tacos, and why is it so special? I just went through el paso a week ago. I fill up in el paso to and from Phoenix, because its about as far as you want a tank to go, and its the farthest West you can get Taco Cabana.
Also for the rear accessory panel, my plan is to install some USB inputs. There used to be so many different types of chargers, but now its really just Samsung and apple. Makes it easy to leave 1 or 2 cables back there (out of the way) for rear (or front) passenger charging. I was going to use a retractable cable and store it in the cubby slot.
