Ok so I came home from work and the tahoe started just fine but when I tried to get back out...Nothing. The key fob will hardly lock the doors, same with the locks on the door. The Interior lights dim and flicker. When I put the key in the Ignition the chime comes on fine but when I turn to run or try to start, all the electronics turn off and the check engine light flashes. When I take the key out the gauges move and reset. All my grounds are good. Does this sound like a BCM issue or something else?
