when you take the key out and get out of the vehicle the radio stays on untill the dome light goes off
Before all this happened the radio would turn off if the keys are out of the ignition and the door opens. The Ignition switch tested fine so I ordered a BCM off ebay (same part number as my current one) and I am going to try this and see if it will work
30 Minute Learn Procedure:
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON, vehicle will not start.
3. Observe the SECURITY telltale, after aproximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1-4 two more times for a total of 3 cycles/30 minutes, the vehicle is now ready to relearn the PASSLOCK sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important:
The vehicle learns the PASSLOCK Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password.
7. With a scan tool (like the ones you buy at autozone) clear any DTC's (trouble codes) if needed. DTC's will self clear after 100 ignition cycles.
