TailLight Problem :(
M1Gunner
Gainesville, Fl
Just to add to the confusion, most GM assembly line robots are made by Fiat.
lol debatable! Robotics have nothing to do with engineering wiring harnesses! Hahaha that has nothing to do with our beautiful hoes.
SmileB44Death
SmileB44Death
Seattle
I didn’t know people replied but thangs for your attention and I’ve replaced the license plate bulb I still have this problem. But the thing is my tailights
jmm121783
Searching for the next sunset...
Detroit
Here's the thing my break lights work my turn signals work but my running tailights don't work and the right license plates light doesn't work but the left one does. Does anyone know what's going on? And does anyone have the electrical diagram for the rear end?
I just had the same issue and I ran a line from the passenger side harness to get my running lamps working...super simple and affective. There must be an issue where the chassis harness Ys into the seperate tail lights
SmileB44Death
SmileB44Death
Seattle
Could you help me out I’m a visual learner so could u be kind enough to send me a video that would be really helpful @2069540414
it has been my experience that the contacts will get funky and sometimes even melt the plastic a little from the heat, I would take a good look at the contacts and be sure the bulb(s) are good, sometimes part of the bulb will burn out if it is a 2 filament, if the contacts have any black buildup (residue) try cleaning them first and bending them in a little so they have a good firm contact, my license plate bulb was flickering recently and I just cleaned it up and tweaked the contacts a hair and works perfect again. but I have had to replace the end harness before because it was just shot, on all these gm's there is end harness under the rear bumper (directly under the left/right sides) that feeds up to the lights it can be replaced by just unplugging it and plugging in a new one if need be.
audley71
