Tailpipe Smoke???
SunlitComet
OBS Jedi-Do Good
unknown at this time.
It only puffs for a second.
Ch@d
If you plugs stay clean and it does not show up any other way I would to leave it for now unless you really want to get into with testing. Take picture of plugs for comparison and if it gets worse or at about thousand mile or so remove the plugs and reinspect. If you want to do some serious testing you can do cooling system pressure, combustion and leak down tests to narrow it down.
Smasal
Smasal
Southwest, Mo
Had the Tahoe inspected today for tagging and licensing tomorrow. And my shop is same shop my grandad used so I know they will shoot me straight. And they actually saw the smoke and said it's more like water. White = water? Blue = Oil. He said mines definitely not oil. Based on a couple other things he checked.
I'm a 1k miles from my next oil change so I will reinforce then and let you know.
With the heat being over 100 here for more than a month he said no way of knowing if coolant was leaking or whatever without finding a source. Because it's sooo hot. But I brought it home tonight and wiped off everything I can reach with my fat arm. And will check it again tomorrow.
Ch@d
Smasal
Smasal
Southwest, Mo
So he decided to that water wasn't gonna hurt me if I was burning a little when I started it. Because u never see it again?
Ch@d
jkorvette
