Taking a trip with the family...
Pachanga02
Ny
Please delete all questions were answered
Alex33
Not sure about the freon but 40psi in the tires is good and you can get the Esky 22 up there w/o a problem.
Pachanga02
Pachanga02
Ny
Thanks Alex, I wasn't sure about the 22 since there is a bit of weight difference from that and the stock spare 16. I got rid of it since I can't use it on the front and have another Denali rim. My only concern was that I didn't want the hanger to brake from the weight of the 22. Hopefully someone will help me out on the freon.
hiles
I always fill her up with max pressure, it drops over time.
JochenWoern
Sacramento, CA
Filling her up with max. pressure is a good way to ruin your tires quickly. You should only inflate to max. pressure if needed depending on the weight you will carry in the vehicle.
Of course the pressure will always drop over time, but first the air pressure will increase while the tire gets warm.
I suggest to inflate to the appropriate pressure based on the running conditions of the vehicle and regulalry checking the air pressure.
Always running at max. pressure will make your tire look like a balloon and it will wear a lot faster in the center.
I run my Dueler's 275/55 R20 at 35PSI COLD and only increase the pressure if weight is added to the truck.
Pachanga02
Pachanga02
Ny
Sounds good. I'll keep them at 40psi. I always check them when I'm getting gas on the drive there.
CEN2MENTAL95
Banned
Expensive Long Island, NY
honestly, if you drive more than a block or two especially when its hot outside, your air pressure is already off by +2psi or more....
you need to check them COLD COLD COLD in the morning for the most accurate pressures
Pachanga02
Pachanga02
Ny
Well I'll check it in the morning and as I stop I'll check them. Thanks again for the input
DwhiteReaper
