Tell you some of my problems I'm having
IowaTahoe
Iowa
I've got 2002 5.3 Tahoe. I've got a stumble when it's cold, it's getting 8.5 to 11 mpg. Today it really stumbled when it first started, then it died. I tried three times and it wouldn't start. Had to floor it then turned the key and it finally started.
Hoping someone can give me some ideas of what might going on. I was thinking intake gasket but today it didn't want to start at lunch like I was stating and now I'm trying to sit back and rethink it
thanks
IowaTahoe
IowaTahoe
Iowa
I took it to O'riellys and it says theres codes but it couldn't pull them.
Guy that tried to pull them is a SAE mechanic that part times the counter. So I do trust his experience, he recommended me to take it to a Chevy Dealer. Kind of really dont want to go that route right away.
matt14
san leandro,ca
Why were they not able to pull the codes? Are you sure that he was a ASE certified ( all ASE certified means is that you can take a test) technician and not a ASE parts certified tech? Ylou may be able to go down to Kragen and buy a scanner and run the codes to see what you get. This would help a lot in trying to figure out whats going on with your truck. But sounds like a possible fuel problem just off your explanation.
BOSS
The People's A D M I N
Dallas
First thing I would do is the easy stuff, clean the MAF and the throttle body with approved cleaners. If you don't have MAF cleaner, use brake parts cleaner...leaves no residue. Worth buying the MAF and the TB cleaner tho and do it regularly. Make sure to open the fly on the TB and clean it out good with a rag..don't spray too much on.
Maybe a fuel filter too, easy $14 fix...but you'll need that special tool to remove the quick connect.
http://www.amazon.com/dp/B000K1IVV4...e=380333&creativeASIN=B000K1IVV4&linkCode=asn
B
IowaTahoe
IowaTahoe
Iowa
I'm not sure why it wouldn't take the codes, not sure if there was something wrong with the device or what. But the guy that was running the scanner, is a mechanic at a GM dealer here in town. He helps out part time at O'rielly's. He wasn't sure why it wasn't getting the codes, just recommened to me to take it to the dealer where there scanners were better.
Where in Iowa are ya?
I'm in Le Mars, Northeast of Sioux City about 25 miles.
http://www.amazon.com/dp/B000K1IVV4/...4&linkCode=asn
Thanks BOSS I'll start on that today.
amaz
Helsinki, Finland
You shouldn't need any special tools to replace fuel filter?
How much you did have fuel in tank when this happened? I had a bad fuel pump and my tahoe did same kind of shit when it was 1/2 tank or less at the beginning, and few weeks later it begin to die every time I released throttle even with 1/1 tank. I replaced the fuel pump with new one and all that stumble and dying was gone.
IowaTahoe
IowaTahoe
Iowa
Does anyone know what the Fuel pressure should be at the fuel rail?
Burgy
