Temp gauge rising and falling?
C
Caldwell83
Dothan, AL
I assume I need to go ahead and replace the heater core too, or is there a fix for it being clogged/plugged?
chauncey0337
MLT, WA
You can flush the whole system with prestone super flush. You can drive with it in your system for a day or two, then flush it with garden hose. Much easier than replacing heater core.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
just use a Prestone rad flush kit and cleaning solution to clean and back flush it first. You do sound like you got low fluid levels somewhere if you hear gurgling in the dash.
C
Caldwell83
Dothan, AL
I'm going to go ahead and put a new radiator in tomorrow and see if that solves the problems. Hopefully it will!
jvelderman
