The deed is done. Took out autoride, 2" lift, Bilstein 5100's and z71 coils
ashm
Anyone ever lift a yukon denali 1500 XL? I have an 07 and heard its a pain because of the autoride (which i know i can switch out) but I also heard that the front drive shaft is different from a regular truck which makes it more difficult and more expensive. Is this true? I looked up some lift kits and didn't find anything cheaper than 2800.00 Id like to lift it about 4/6 Inches. ALSO, I am due for new tires, like now, what is the biggest size mud tires i can fit? It is currently stock height with 20" XD wheels.
TheAutumnWind
Yes but its a totally different truck than this one. start a new thread! :)
Joshuasvt
Everett, Wa
Owl the parts you used, would I use the same parts on my 05 denali? Specifically the Bilstein 5100s and the Z71 spring....
Thanks
owl_93
owl_93
Thanks
I believe so!
Sent from my SM-N920T using Tapatalk
TheAutumnWind
Thanks
yes. part finders will say otherwise since you would have to delete autoride in order to install them though.
I have bilsteins and z71 springs on my denali with autoride deleted.
To clarify I trimmed the springs to maintain factory ride height roughly, and I am running the 4600s due to that, however the 5100s, key lift and the full spring would work fine and you'd get the same result as owl.
I wanted the z71 springs for a slightly higher spring rate.
Jonrobinson84
This is going on the bucket list for the XL! Just need to find that steal of a deal for the right tires!
Did anyone see a MPG change after moving to the 280s?
CamReynolds
So I finally got all my suspension parts put in my Hoe and got a new set of tires and wheels. I downsized my 20x8's to 16x8's and sized up my 275/55 AT tires to 285/75 MT tires.
2.5" front lift from new keys, and 2+" rear lift from z71 coils and 1.5" coil spacers. I couldn't be happier with the look and more importantly the ride.
Before:
After:
are your keys maxed out to level with the spacer/ z71 springs? id like to get spacers, shocks, springs, but dont want to max out my keys in order to level it out again
CamReynolds
that looks so sweet !
not sure if I ever posted mine as I sadly dont get on here much
I too went with the moog 81069 Z71 coils though I added Mcbay 1.5" spacers as well to the rear & 2.5" leveled on the front
& this spring we had to remove some cancer so it was all new panels & then monstaliner
with the help of my son we also built a rear tire carrier
are the keys maxed out?
CamReynolds
Before:
After:
fender heights? from ground to top of fender?
boutrous
