The KidWagon
KidWgn
KidWgn
Certified Kid Hauler
St. Louis, MO
Aren't drop shackles for leaf springs?
May be the wrong terminology. It’s what I’ve always called it though; it’s used to drop the location of the shock, and another to drop the location of the lower trailing arm. Pic attached of the trailing arm shackle
kbuskill
NE. FL.
I still have my sensors and whatnot. Did you keep the factory air shocks, or did you retrofit bags?
If you kept the factory air shocks, I'm assuming you're using a 4" drop shackle?
I do have the axle relocation brackets similar to the ones pictured.
I researched and found an aftermarket air shock with the same collapsed/extended length as the Belltech drop shocks and ran those.
They rode nice, my only complaint was if you get into a situation where there is a repetitive bounce, like when coming off of certain bridges, they were softer than I liked.
KidWgn
KidWgn
St. Louis, MO
Pictures as promised. This is with the axle sitting at ride height.
Here’s the clearance on the diff cover. It’s around .200-.250
View looking up, top of picture is forward.
KidWgn
KidWgn
St. Louis, MO
KidWgn
KidWgn
St. Louis, MO
Good to see you tinkering KW.
Always tinkering brother! Work has just been nuts, so I haven't been posting much. I'm about to tear my front suspension apart again. I finally figured out the issue. The front coilovers' struts are too short, which is why I had to crank the spring perches up so high. I'm going back to OE spindles with the coilovers, which should resolve a lot of the issue. Hopefully it resolves the RF wheel jutting outboard, too.
KidWgn
KidWgn
St. Louis, MO
Installed my Improved Racing thermostatic trans outlet and the smaller Derale 10-row instead of the TruCool 40k.
Hard to say if it’s “better” since it’s been under 40° here for quite a while.
I will say, with the 40k installed, sans radiator loop, I wasn’t even achieving 100° trans temps on my way to work. Now I’m able to achieve 170°, allowing for moisture to evaporate from the ATF.
Once it warms up in May, I’ll know whether the Derale is enough to keep up with high ambient temps and a 3200 rpm stall.
Imgur link to photos
17XLDENALI
