The next issue... Squeaks
Oobray
Now that I got my HVAC blend motors fixed I've moved on the the go ruble squeak under the hood. I figure it would be the idler or tensioner pulley so I replaced those. Still squeaks. I took the A/C belt off to see if it was the A/C tensioner, still squeaked. Spun the fan by hand, doesn't seem to be it. Ran it with no serp belt at all (only a few seconds) No squeak. Ok so I know it's not any of these...
1. idler
2) Tensioner
3) A/C
4) Balancer
5) Prob not the fan (can't know for sure)
Only pulleys left are PS pump and alternator. I replaced the alternator about 3 months ago trying to fix this same problem. Is it possible this one is bad already? Can anyone think of a way to spin the alternator fast enough by itself to see if that's it?
JKmotorsports
Austin, TX
Use a length of tubing with one end to your ear and the other to the suspect part. This will make it a lot easier to isolate where the noise is coming from.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Be careful doing that when reaching in to get close for hearing. Best to use a mechanic's stethoscope and pinpoint the noise. Could still be fan because your hand spinning it does not create pressure. I did miss the year and engine size at first, sorry. 02 8.1 L.
With the 8.1 is it just one belt only with 1 idler and 1 tensioner or 2 belts like the 5.3? Read it again and answered my own question. You have 2 tensioners. Replace one or both? Could be either of the component pulley bearings. I like the stethoscope for chasing noises.
ezdaar
Chat Troll
Redneck central, Aka Houston
use a paper towel roll "Thin cardboard" if you EVER stick your head to something to pinpoint a engine noise!
Nothing hard, or long and bendy like a hose or tube.
Watched a guy get knocked the **** out doing that. ******* used a short wood handle from a window cleaner. it hit the fan when he repositioned it. luckily it didn't cave his skull in.
But yess I do this frequently when searching for noises.
ezdaar
Chat Troll
:Get him!:
:yaoface2:
I have one of those fancy pants "automotive stethoscopes"
Its been hanging on the wall from day one. it no work.
A real stethoscope, sure.. but whose got time for all that nonsense of using a "correct" tool..
I use a screw driver as a hammer most of the time. :roflbow:
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Use a mechanic's stethescope (a fe bucks at harbor freight). Have a friend hold the steering wheel at full lock (left or right, doesn't matter) to put a load on the belt so you can really hear her squeak. But the probe of the stethescope at the base of the pulley's shaft bearing area (non-rotataing part). See where it is loudest.
O
Oobray
Raider on, I replaced the main tensioner and the noise remained. I took the secondary (a/c) belt comolet off... Noise remained. I'll try listening with some form of "doohickey".
Any tips on listening to the fan?
meatball4u
