ivin74
05 NBS Nali
Hello guys
About 4 years ago I bought a 06 Sierra Z71 with 101k miles from one of my neighbors. I did regular oil changes (always used Castrol full synthetic oil) but not much maintenance as the truck has been very reliable. Now that the truck has hit 211,*** miles it was time to start doing some major maintenance as I started to see some oil wet spots through out the motor. So this weekend I removed the front diff and replace all the seals on the front diff as 2 were leaking, the internals looked good. Since the front diff was out already I replaced the oil pan gasket (not leaking just wet), to my surprise I did not find any sludge on the oil pan so I installed everything back and moved to the top of the engine. The valve covers were also wet and so was the valley pan area. I then removed the intake manifold, valley pan along with the valve covers. I was also surprised to see that the head internals were clean (no sludge what so ever). So I figure I would share the picture of the head internals for you guys to see, and see why it's always good to use synthetic oils.
