thehoe92 Lowered 3/5
thehoe92
thehoe92
fo sho
The916
clean will be able to elaborate a lot better than I would
I just had to keep checking with him as he was explaining it that it would make me lower :D
the top bushing it metal on top and half way down has a rubber boot
take the rubber boot off and you expose what chris is cutting on in the picture
keep the top rubber boot off and put the metal back on put the bottom rubber boot on and thread the bolt a little bit
tighten each one about half way
then go back again and tighten all the way.. you will see the body suck in closer to the frame
Blizzard and I were standing at the back of my hoe while clean was tightening the bolts and we were watching the gap between the back bumper and hatch close up.. our worry was that the hatch wouldn't be able to open but I got lucky and you can just barely slip a pencil in between it
pester Blizzard about posting pictures of it and he'll eventually post them, it will better illustrate what I'm trying to say
---------- Post added at 01:13 AM ---------- Previous post was at 01:10 AM ----------
found another picture
denalianyone
NYBlackLade08
New York
ok i took a look at my truck a few minutes ago...that boot can be cut rather easily...same procedure as trimming your rear bumpstops...good find fellas!!
denalianyone
NYBlackLade08
New York
shit ever since JK dropped his lower with s-10 body mounts i was researching and to no prevail. This may be a simpler tactic.
thehoe92
thehoe92
fo sho
The916
I always thought body drops were really intense procedures that only shops could do because you had to lift the whole body off the frame at once
the s10 mounts are from my knowledge for ride quality.. since your frame is now touching the body there is no separation which is another reason why when I bottom out it is quite intense
I'm sure there are also kits that let you body drop while keeping some type of separation between the frame and body
the rear hatch was about 1.25" from the bumper before we started and now its less than an 1/8th of an inch away so I gained a little over an inch
---------- Post added at 09:38 AM ---------- Previous post was at 08:28 AM ----------
got 1 bracket off
I love the sawzall I've never used one before but damn!!! :D
Narco
Atlanta
are you done w/ the whole mod yet? how does it drive now? is ride quality gonna suffer?
thehoe92
thehoe92
fo sho
The916
both are off..
I stand corrected.. I only like the sawzall when it has a new blade
the drivers side took way longer because I had to fight with it a couple times
got a lot more clearance than before but now that I don't bottom out my tires hit the back fender
I drove to work and heard some scraping even though I trimmed the plastic fender liner
get out and smell burnt rubber and it was "sanding" away at my tire, its a little rough now
but I won't be able to judge ride quality until I get some shocks in haha!
dylansmashed
