Thoughts on upgrading my 20" rims to 22" What tires do you like/dis-like?
BADRIDES
I run 275-55-20 in the winter and 285-45-22 in the summer
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I went back and re-read the OP’s post. It sounded like he was looking to go to a larger overall diameter combination. That would mean a change to his speedometer if he deviates too far.
lowpost99
lowpost99
Lowpost99
Atlanta, GA
Yes, but what overall diameter will be too much and cause rubbing, at what height when lowered that's what I don't understand yet either.
lowpost99
lowpost99
Lowpost99
Atlanta, GA
Im not sure about the correct answer there, but I'm guessing that 22" wheels/tires are less $$$ than 24 or 26 inch wheels tires. If this is the case, I'd like to fill the wheel wells for a sportier look, and I thought that lowering was part of getting that look if the wheels were not gigantic.
TheAutumnWind
You've got the right idea. How low do you want to go? A 2/3 drop is pretty economical and makes a big difference in the look. A 2/3 on 20's with stock tire sizes (32" diameter) is a pretty sporty look imho but thats just an opinion.
lowpost99
lowpost99
Lowpost99
Atlanta, GA
Does 2/3 mean two-thirds of stock top of fender? Can I adjust the stock keys down vs. up? What about this free travel mod? I read that it lowers 1". What brands of replicas should I stay away from? I've heard that some can break on potholes easily.
rgosart
A 2/3 drop is 2in front and 3in rear.
You can adjust the keys down, but I don't know how far.
As far as I know (I'm not very well versed on lowering) the free travel mod does not lower a vehicle any. Just increases travel as the name suggests.
TheAutumnWind
As @rgosart said. X/X is referring to inches of drop front & rear respectively.
Stock keys can be adjusted down a little without a noticeable penalty to ride quality. How much exactly is up to you... I'd say @ ~1" drop ride quality isn't bad. If you want more you really should go with some drop spindles.
But why take my word for it, it costs zero $ and however long it takes to jack up the front end and back off the torsion bolts a little...15 mins max?
The rear can be accomplished easily with a spring swap. And some more work if you have air ride.
We should probably start another thread about lowering your truck though before I write a dissertation on lowering in a thread about tire recommendations....
Dalewg
