BADRIDES
- Joined
- Dec 18, 2015
- Posts
- 1,737
- Reaction score
- 1,152
I run 275-55-20 in the winter and 285-45-22 in the summer
Yes, but what overall diameter will be too much and cause rubbing, at what height when lowered that's what I don't understand yet either.I went back and re-read the OP’s post. It sounded like he was looking to go to a larger overall diameter combination. That would mean a change to his speedometer if he deviates too far.
How low do you intend to go?Yes, but what overall diameter will be too much and cause rubbing, at what height when lowered that's what I don't understand yet either.
Im not sure about the correct answer there, but I'm guessing that 22" wheels/tires are less $$$ than 24 or 26 inch wheels tires. If this is the case, I'd like to fill the wheel wells for a sportier look, and I thought that lowering was part of getting that look if the wheels were not gigantic.
Does 2/3 mean two-thirds of stock top of fender? Can I adjust the stock keys down vs. up? What about this free travel mod? I read that it lowers 1". What brands of replicas should I stay away from? I've heard that some can break on potholes easily.
As @rgosart said. X/X is referring to inches of drop front & rear respectively.Does 2/3 mean two-thirds of stock top of fender? Can I adjust the stock keys down vs. up? What about this free travel mod? I read that it lowers 1". What brands of replicas should I stay away from? I've heard that some can break on potholes easily.
